13.3.1 - PCSD- DeltaV Operate
Lately our Process Historian is really slow. When you pull up a historian view from the faceplate it will take forever to pull up the trend(s). When you increase the time span, the symptom is the same. It seems to have to do with accessing the archived data. Our Ap Station is our Historian. It runs on a VRTX. Our system is made up of both VMs and physical workstations. The problem seems to span across both types of machines.
I wasn't sure what tools, if any, there are to help narrow down the source of the problem. I checked hard drive capacities and misc data from the Application Server but didn't see anything out of line.
I'd assume there are some tools that might help narrow down the problem or at least trigger some new questions.
Has anyone seen a similar problem or have any advice?
Thanks!
Kathy Pate
Toray Carbon Fibers America
Decatur, AL 35601
kathy.pate@toraycma.com
