LSAVTR Status Propagation in CSLS Rev 2 DV Version 14.3
When using CSLS Major Revision 2 I am no longer able to propagate status to the output of the LSAVTR block. There was no issue with this in CSLS Major Rev 1 nor SLS 1508. The release notes for 14.3 note that the voter block in revision 2 has a timeout parameter that delays the bad status propagation by a predefined time. What it actually does is delay the trip on bad input status but does not allow the status to propagate to the output. Is there a way to get the voter to pass the status to the output?
