I am trying to integrate a device using PK100 Controller via Ethernet/IP using Class 1 Implicit.
My DeltaV Version is v14.FP2 Build 7944. My PK100 controller firmware was at SwRev 14.3.0.6843.xr. I was able to communicate with my device at this firmware revision.
I recently upgraded the PK100 controller firmware to SwRev 14.5.1.7944.xr. After the firmware upgrade, I am no longer able to communicate with my device even though all the IP addresses, assembly instance configuration and signal configuration is the same.
Is there any additional step required after this firmware upgrade?
In reply to Chaitanya Adkar:
