diaphragm seal 1199
I have one DP transmitter with diaphragm capillary seal, the ordering number for Seal is 1199DA356AFCS74VI00ZT . i try to find the detail configuration of ordering number, but in new document revision is meaningless. can you help me? the transmitter is built in 2000 (i think)
Thanks
  • Hello,
    Your Model Number 1199DA356AFCS74VI00ZT can be broken down as follows:
    1199 = 1199 Seal System
    D = Balanced
    A = Syltherm
    3 = 2mm
    56= 3 meter
    A = ANSI
    FCS = RTJ Flange
    7 = 3”
    4 = 600#
    VI = 2205 Duplex body, Alloy C-276 diaphragm (one piece)
    Z = Material certs to DN10204 DIN 3.1B
    T = NACE FR-01-75
    As there have been some minor updates to our 1199 model options, the below model is an equivalent system and will need to be used on future orders:
    Updated Model Number: 1199DAD56AFCW74V100Q15E
    D = Welded-Repairable system
    A = Syltherm XLT fill fluid
    D = 0.075 in. (1.905mm) capillary ID
    56 = 3m capillary length
    A = ANSI
    FCW = Ring Type Joint Flange, Flush Surface
    7 = 3in. process connection size
    4 = class 600# flange
    V1 = Alloy C276 Diaphragm, Duplex 2205 Upper Housing, 2205 Duplex Mounting Flange
    0 = No Flushing Connection
    0 = No Lower Housing
    Q15 = Certificate of Compliance to NACE MR0175/ISO 15156 for wetted materials
    E = One Piece Design
    In order to get the Material Traceability Certification per EN 10204 3.1B (your “Z” option code), you will need to add the “Q8” option to the Rosemount transmitter model number that will be attached to the 1199 system. This certificate will cover both the transmitter and 1199 models
    Please let me know if you need any additional assistance.
    Best Regards,
    Ryan Kees,
    Sr. Product Manager, Emerson Process Management
  • Hello MOH,
    Here is what we found:
    Your Model Number: 1199DA356AFCS74VI00ZT
    1199 = Rosemount Diaphragm Seal System
    D = Balanced
    A = Syltherm XLT Fill Fluid
    3 = 2mm capillary ID
    56= 3 meter Capillary length
    A = ANSI Flange
    FCS = RTJ Flange
    7 = 3” Flange
    4 = 600#
    T = NACE FR-01-75
    As there have been some minor updates to our model options, the above model code can no longer be ordered. Thus, we have created an equivalent model code using current options which can be used to order future replacement parts:
    A = ANSI
    *Please note that in order to get the Material Traceability Certification per EN 10204 3.1B (your “Z” option code), you will need to add the “Q8” option to the Rosemount transmitter model number that will be attached to the 1199 system. This certificate will cover both the transmitter and 1199 models
    Best Regards,
    Ryan
    Ryan Kees | Product Manager, Rosemount Pressure Products
