Hello All,
Has anyone been successful in commissioning of SEL-2488 satellite network clock to synchronize time in DeltaV? Presently, the plant is on version 13.3.1. I set up the NTP server using Plant LAN -- the third NIC of PROPlus with successful connection, configured remote network of PRO+ with proper IP address; however, Diagnostics show None in the status of the NTPServer parameter. Also, I've tried connecting SEL clock to the 1° control network, assigning 10.4.128.1 per BOL, but failed to ping the node from PRO+ and Application stations. GSC attributed my failure to the unsupported device by DeltaV...
