Has anyone successfully set up a remote NTP server for an application station with DeltaV 14.3.1? I have two DeltaV systems and want to put a GPS NTP server in the DMZ. Each DeltaV system has 2 application stations on the L2.5 network, and I'd like to have one app station as Master Time Server and the other as Backup Time Server on each DeltaV system. Our IT group can use the NTP server as well.
The updated KBA NA-0200-0147 indicates setting up a remote NTP may not work. KBA NK-1800-0105 gives a workaround of deleting the default server IP addresses from the NTP.CONF file, and I'd like to know if this actually works before we purchase the GPS NTP Server. Also does anyone have a preference between the Spectracom SecureSync 1200 and Microsemi S650?
I appreciate all the prior contributions regarding NTP and the GPS NTP time servers:) It seeems a lot has changed with the newest versions of DeltaV.
Thank you in advance for any replies!
Kathy Pate
Toray Carbon Fibers America
Decatur, AL 35601
kathy.pate@toraycma.com
In reply to Alexandre Peixoto:
