We have a heat exchanger that cools the process stream with a temperature controller. The temperature for this feedback PID control is the process outlet temperature from the heat exchanger.
I would like to add a feedforward input to the PID function block but I'm not sure how the status will be handled. If the feedforward variable status goes bad, how will the PID function block handle it?
I am planning to use a feed tank temperature as the feedforward variable for the downstream temperature controller. Ambient temperature swings the feed tank in 24 hour cycles and I'd like to isolate the heat exchanger's tuning from ambient influences.
