Guardian KBA AP-0900-0040 provides packages for a "batch install" of approved security updates, and I was curious why after uploading the latest REG file Guardian still showed I had a server that lacked a recommended update.
Launching it manually, the missed package eventually indicated "insufficient disk space" to install the patch. A glance at file explorer showed less than 2 GB remaining on C: drive.
I didn't see the insufficient space alert because the batch installer silences all console interaction (thankfully).
So a couple thoughts:
1.) One should always ensure sufficient disk space on C: drive. Maybe try installing the big cumulative Windows update manually.
2.) What's the least disruptive "supported" way to increase the space on C: drive (e.g., without doing a total OS & DeltaV reinstall)? D: is on the same physical RAID array and has abundant unused space . . .
-John
In reply to David Foose:
In reply to Benji_Kidmose:
In reply to Tim Alexander:
In reply to John Rezabek:
