Hello,
I have a customer who currently uses Aspen Batch and is considering moving away from it to something else. One of the options for consideration is the DeltaV Batch Historian. In an effort to map out the pro's and con's, I am considering the methods of data entry into the Batch Historian outside that of the report parameters in a phase.
In the particular system architecture I'm looking at, there are batch related items that execute outside of the traditional phase/unit structure that we don't capture with OAR's. A couple of examples would be: Tank sticking and Operator PIN entry. In our case, we use external control modules that the batch and the operator interfaces with to enter that particular data.
What I would like to do is have some mechanism to transfer data from those external modules into the Batch Historian for that batch. In Aspen (and probably every other external batch historian) that data and an associated trigger is monitored for collection. Can the Batch Historian do something like this? Everything I've read seems to indicate that the answer is "No."
This would be in DeltaV 14.3.LTS.
Thank you,
Dave
I would say don't touch Batch Historian database. One of the reasons is to say compliant with CFR Part 11 and even if this is not needed, you may should consider potential issues (big issues) when upgrading/rebuilding DeltaV system. "there are batch related items that execute outside of the traditional phase/unit structure that we don't capture with OAR's. ", I think this is the root cause for your need. Batch items implemented outside DeltaV Batch, those will be better implemented into DeltaV Batch to have them under DeltaV Batch umbrella. So "natural" mechanism should be executing a DeltaV Batch phase that reads those values and creates Report parameter values. The hard part will be how to activate that phase, from executing recipe or standalone but automatically because for each use case it could be needed to implement a different solution.
In reply to gamella:
In reply to dave_marshall:
