In a project, there is a requirement to configure rate of change alarm for Pressure as below:
The time averaging period should be configurable.
I have tried using PCSD composit C_AI_RATE52 (PCSD Composite for Rate Alarming for Analogue Input). However not able to understand how exactly calculating the ROC parameter. Has anyone used this composite for such application?
What is the formula/calculation used to determine ROC? Which parameter is to be used to configure time averaging period?
In reply to vmvmhatre:
In reply to Nandkumar chandra:
In reply to Andre Dicaire:
In reply to DBacker:
In reply to SBPosey:
