Matt Stoner - Any chance you recall what all may have changed in the v13 module templates aside from the content of the CALC block, where alarms are set to OOS as opposed to OPSUP?
I'm thinking I can just cut-and-paste the code from the new templates to the modules created prior to v13. Or would you recommend just deleting them and reconstituting them using the new template?
John
Here are the changes I see in v13 vs v12:
ALM_FLOOD_SUP
ALM_FLOOD_SUP_32
FO_ALM_SUP
So if you get all this in your copy and pastes you should be good I think. Make a backup before starting first...
In reply to Matt Stoner:
In reply to John Rezabek:
