I have issue with ACN switching over between primary secondary then I/O failure of remote CHARMs for about 0.001 second. Laterly I’ve found that one of my Emerson Smart switch in Primary network is commissioned but showed red cross in DeltaV Smart Switch Command Center. I’ve check LED on this switch they are running and healthy. I’ve trìed to use telnet to login but don’t know the user name and password. My question is what happen with my smart switch? how can I fix it? Is it possible that ACN switching over causing remote CHARM I/O failure alarm. I’m using DeltaV v. 13.3.1
Thank you in advance.
