I've read elsewhere that one should avoid using CALC blocks when it's not required (mainly because of the impact on controller loading, and module execution priority). At what point would a CALC block be better than multiple logic & math blocks? How can I determine the 'better' method? I haven't figured out how launch the Load Estimator utility in Simulate...
As an example, I want to hold the last input value if the status is bad, but I also want the output value to have the same status as the input value. Which method is better in this case? A CALC block.... or a CND, XFR, ACT & some math block?
Thanks.
