In DeltaV I'm trying to change the Engineering Units of the OUT_SCALE parameter of an instance of the C_AI_SOFT130 composite via CALC block.
In the CALC block I've tried the following lines but none of them seems to work:
'^/AI1/OUT_SCALE.UNITS' := 1607;
or
'^/AI1/OUT_SCALE.UNITS' := "cm";
Do you know if this is at all possible?
Thank you for your help
In reply to Matt Stoner:
