Event Chronicle Problem
An Alarm is appearing on all workstations- EWS  "Failed" " event Chronicle database is not available" EWS  is our Pro-plus. Delta v Version is 11.3 OS-Windows7 Workstation is Dell RAID Enabled. When i Checked on proplus in events & Alarms the Server availability alternates from yes to NO in few seconds .pl. help to resolve the issue
  • Call GSC!
    In the meantime, can you check Windows Event Log - Application or System or DeltaVChronicle for error or warning that might be related to Event Chronicle?
