Continous Historian question
 I add points to historian, I build a trend chart based on these points. I upload them to the pro station, send them to ops stations. I can find them and look at them but only thing they ever display is real time data. it is not archiving data in order for me to look at trends? any help would be appreciated.
  • Ensure the default data server on the op stations is set to your historian. You can do this in process history view under file and "set default data servers". If you don't want to change the default servers on the op stations you can also change the chart configuration to use a specific historical data server rather than the default.
  • thank you for the help.
