windows 10 supports Deltav 11.3.1
Hi guys, I want to know is it possible to install DeltaV ver 11.3.1 on windows 10?
thanks.
  • Hi, Hamed. Windows 10 isn't supported until DeltaV v13.
  • We use VMs to run older OS versions. Hard to find drivers for new hardware that will run on older Windows versions.
  • In reply to Andre Dicaire:
    For those who are still running v11 or v12 and need workstations or servers that will run Windows 7 / Server 2008, or are running DeltaV Virtual Studio v2.3.x, Emerson still has a limited supply of new Dell units with a full warranty.  Models and compatibility are listed below:
    • SE2702C02 - R730XL rack-mount server compatible with DeltaV v11.3.1, v12.3.1, v13.3.1, v14.3, v14.3.1, and will run both Server 2008 and Server 2016
    • SE2602C01 - T5810XL tower workstation compatible with DeltaV v11.3.1, v12.3.1, v13.3.1, v14.3, v14.3.1, and will run both Windows 7 (32-bit and 64-bit) and Windows 10
    • SE2603C01 - R7910XL rack-mount workstation compatible with DeltaV v11.3.1, v12.3.1, v13.3.1, and will run both Windows 7 (32-bit and 64-bit) and Windows 10
    • SE2705V01 - R730 Host Server rack-mount compatible with DVS 2.3, 2.3.1, 3.3, 3.3.1, and will run Bare-Metal HyperV of Server 2012 (Not R2) for DVS 2.3.x, and Bare-Metal HyperV Server 2016 for DVS 3.3.x
    • SE2703V01 - Virtualization Domain Controller / Host Management Server (based on R430) rack-mount compatible with DVS 2.3, 2.3.1, 3.3, 3.3.1, and will run Server 2012 or Server 2016 Std.
    • SE2706V01 - Virtualization Host Blade Server (based on M630) compatible with DVS 2.3, 2.3.1, 3.3, 3.3.1, and will run Bare-Metal HyperV of Server 2012 (Not R2) for DVS 2.3.x, and Bare-Metal HyperV Server 2016 for DVS 3.3.x
    Contact your local Emerson support company for pricing and availability.
