Hello,
I have DeltaV V12.3 in my system, I want to move a professional station license from one station to another and I haven't done it for long time, so please help me with the following
As far as I know I have 2 options how to do it
Option 1 - I will do these steps:
A- Export the station FHX file
b- Delete the syntax related the license without effecting the code in the Notepad to free it up
c- Re-import the FHX and download the station after assigning an ordinary operator station license to the node
Option 2 - is simply delete the entire node from the DB to free up the license and add it again with running a workstation configuration on that operator station
So here's my questions,
1- Are these options right ?? and which one is better??
2- If I wanted to do Option 1 (I prefer this ), how I will delete the syntax without effecting the code in the Notepad ?? below is the code that I want to change, please show me which one I delete
{ ID=974389268 DEVICE_INDEX=15 REDUNDANT=F REPORT_TIME_OUT_OF_SYNC_ERRORS=F SOFTWARE_LICENSE_BUNDLE { ID="19980115.000000 12171" } SOFTWARE_LICENSE_BUNDLE { ID="19990118.122914 00003" } SOFTWARE_LICENSE_BUNDLE { ID="20060622.141748 00099" } VERSION { VERSION="STANDARD" MAJOR_REV="12" MINOR_REV="3" } PLANT_AREA="AREA_A" HARDWARE_ALARMS_ENABLED=F PRIMARY_CONTROL_DISPLAY="" INSTRUMENT_AREA_DISPLAY="NODE_FP" DETAIL_DISPLAY="" AREA_CONTROL_NETWORK { PCN_NUMBER=1 SEGMENT_NUMBER=1 IS_MASTER_TIME_NODE=F IS_BACKUP_TIME_NODE=F } BATCH_HISTORIAN_SUBSYSTEM {
Sal Salamone
In reply to Sal Salamone:
In reply to Mustafa Ajeena:
In reply to JessWilson:
