Hello experts,
I have encountered this issue below (see images below) after re-installing the Deltav system.
From the Diagnostics:
To give you some background, first, after I installed the DeltaV software, I imported the fhx backups to the DeltaV Explorer (DeltaV_System.fhx, Library.fhx, Control Network.fhx, SIS Network.fhx, etc.).
Then, I was unable to import the fhx backup from the exported fhx file for the SIS Network (next to Physical Network) as I encountered some errors (not been able to capture the error msg, my bad).
So, I downloaded each node, EWS-01, PAS-01, SIS-01, and FGS-01. Then, I tried to import again the SIS Network.fhx and still, I'm having the same error msg.
Then, what I did was, I created a new database using the Database Administration tool, and used the latest hbk backup file.
Then I made this new database active and when I opened the DeltaV Explorer, the SIS Network and all cards under that are present under the DOMAIN1.
But the problem is that all SLS cards are having a red-X mark which means, unable to communicate or not connected.
What could be my mistake?
Hope someone could help me. Thanks.
In reply to Nabil BOU:
