I am working on a project where we need a ZONE server for communicating between two DELTA-V systems. The old (Existing) System in a M-Series Delta-V with old Safety Logic Solvers while the new one will be the latest S Series System with traditional acrds for Process and SZ controller with Charms for Safety.
Is there any Version Compatibility we need to check? ( for an older M series System to communicate with the new S Series one).
Also, through Zone Controller, can we get the Historian and Asset Management Tags to the existing system ( without having Historian and Asset Management in the new system)?
Thanks for the help in advance.
My first advise is to check content available on our DeltaV Zones product datasheet at www2.emersonprocess.com/.../PDS_Zones.pdf, which includes the pre-requisites for DeltaV Zones being version 9.3 and higher applicable - this is not dependent on the DeltaV Controller type. The Plant Event Historian (PEH) is indicated to integrate historian data (including alarms and events) from multiple zones into a single database. AMS Device View might be a good option for what you are trying to achieve in the Asset Management realm. Hope this helps! Regards, Alex
In reply to ENGRIMRANTAHIR:
