I have an application where there is an existent DCS and I want to use a Charm cabinet (CIOC) in order to integrate new signals. But I understand that is not possible to connect it with Serie M controller.
In case that will be correct, is there another possibility tu use any Remote IO instead using another DCS??
Thanks!!
There may be one other option that is to use the M-Series Zone 2 Remote IO. This has limitations on IO type e.g. no digital buses so please consider your application carefully to see if this solutions meets your needs. Hope that helps.
