Hello,
I was wondering if it is possible to show batch prompts as well as a button that will go to the OAR in a different picture? I find it inconvenient to have to switch back to the batch prompt list picture every time I want to answer a prompt.
Thanks
In reply to rhamlin:
Creating a picture with the ActiveX inside. A copy of BatchPrompts.grf may be used as starting point: 1 save with different name (I suggest to do "save as" into pic/standard folder). 2 remove unwanted items (buttons to other Batch graphics, title banner, close pic button, etc...). DO NOT REMOVE VariableGroup item 3 resize batch prompts activeX4 configure batch prompts activex to show only required colums (and other properties, font, bck color, etc...)
5 resize graphic to fit into auxiliar area. This could be a bit tricky, some trial and error may be required....
Then create a layout file to include that new pic.
