We always make a graphical display of the fault status of a CEM block with schematics based on CEM.This is just a border that turns red when one effect trips and blinks when the alarm is not acknowledged yet.
To do this we used to put a whole boolean compare in the fields of the rectangle on the display.
I want to switch to a calc block in the module.At the moment I just copied the old compare.It goes like:
REM COLORIF '^/U1503/EFFECT1.CV' = 1 AND '^/U1503/EFFECT2.CV' = 1 THEN 'OUT1.CV' := 1; 'OUT1.ST' := GOOD ;ELSE 'OUT1.CV' := 0; 'OUT1.ST' := GOOD ;END_IF;REM TOGGLEIF '^/U1503/STATE1.CV' = 3 OR '^/U1503/STATE2.CV' = 3 THEN 'OUT2.CV' := 1; 'OUT2.ST' := GOOD ;ELSE 'OUT2.CV' := 0; 'OUT2.ST' := GOOD ;END_IF;
As you can see I have to add all the effects every time we change something.Can't I compare the effect and states automatically in an array?This array is also dynamic so I only need to write it once.
Why not create a customized dynamo and put the codes in graphics - animation instead of a CALC block? -
