Hi All,
I have a query in Process History View.
When there is a change of states, the change is captured in Process History View as 'NEW VALUE = 0, NEW VALUE = 1'.
Is it possible to have a string value instead of floating.
I tried adding A_COMMAND.CVS in history collection. But the PHV still shows floating values.
Thanks!
Hi Rohan,
if the mentioned parameter is taken as string in the control module then only it will show you the string value.It depends on parameter type only. Let me know if you need additional details.RegardsBhushan
