The power supplies in a redundant controller deployment - are they totally independent of one another or do they load share / back up each other? So when I pull a power supply, it should only affect the controller next to it . . . in my case it would be the "Standby" controller's power supply. It only affects the "standby" correct?
My concern is around if they did have some redundancy, one might have a "weak" one on the primary which would potentially fail when the "backup" was pulled . . .
