I would like to know if it is possible to power via different feeds the 2 wide carrier (for a 24VDC power supply feed + MX controller) and an 8 wide carrier (output side) mounted on the same rail.
The goal is to cut field power via a safety relay when predefined conditions are triggered then bringing all the field devices in a safety position.
I need my controller to stay up in order to also trigger a safety logic in parallel to the hardwired one.
m.
