Anyone using module level parameters to set the change per click on a PID faceplate (i.e. the up and down SP and output arrows)?
I want to display the magnitude of a click (in EU for SP or in % for output) upon hovering over the target. So either a module-level variable that was read by the faceplate on Activation / Initialize (preference?) or a picture-resident variable that contained the EU per click is needed . . .
I suppose I would rather put it in the picture / popup since that's a lot fewer things to change, but it is arguably a parameter you might want to "tune" on a loop-by-loop basis.
