I have 2 groups with a rectangle and a piece of text. In both cases I have a click event on the rectangle.
The problem is that in one case, the event for clicking on the rectangle does not trigger unless i click to the side of the text. I don't see anything different between the two. If i move the text over, then I have more room where i can click on the rectangle. It's almost as if the text is acting as a mask. But, this is not happening with other similar groups.
Any idea what might be causing this
In reply to TreyB:
