it is a question for me,when we assign a license like as excel add-in for a operator,all operators can use this feature?I mean that to use excel add-in function in operator group we must order one license for all stations or order per no. of station?
above question is asked totally like as any extra feature license which can add to base license.for example for using control studio in operator station we have to order per no. operator or just order one for all operators.
another question is that as one event chronicle included in pro plus station license,for other stations like as App./operator station need to consider extra license??
also AMS station must be installed on which station category (base station ,application station) ?
moji
In reply to AdrianOffield:
In reply to Moji:
Moji said:thanks dear AdrianOffield ,following are some others unclear point on me. 1-each work station requires a dedicated license to assign to it?for example for control studio online with one license can 3 operator work stations have access to it?(or Excel add-in for operator station usage need to order based on no. of operator work station?) 2-for event Chronicle license.I mean that does we have to order a separated license for other stations or one included in pro-plus is enough to work completely in delta V network? 3-|AMS serverplus requires.is it possible to install to pro-plus?(is it recommended to install on pro-plus regarding to existence system data base in pro-plus station or install in AWS?)thanks again
Moji,
1 - Yes, each workstation requires a separate license for each required feature. Question - why do you want to open CS online on 3 operator stations? I would just assign one operator station that can open CS online or use the PRO+ station.
2 - Event Chronicle is the DB that stores the events, you only need one per DeltaV (PRO+ already has license). Process History View application (PHV) is used to view the event DB from other workstations. Operator licenses includes this application feature.
3- Yes, AMS ServerPlus can be installed on PRO+
All these design decisions depend on a number of factors that determine the best place to install the various DeltaV components. How many DST's/workstations/clients do you have, these factors determine if AMS is installed on PRO+ or on an Application station.
Hope that helps.
