we upgraded our DeltaV system from DV 6.3.4 to DV 8.4.2 .
at first step we found an issue with custom dynamo and related datalink in graphic pages.
All custom dynamo are going to use of bellow expression.
Private Sub AIM_29_MouseMove(ByVal Button As Integer, ByVal Shift As Long, ByVal X As Double, ByVal Y As Double)
'this function is called when the mouse moves over the picture.
On Error GoTo ErrorHandler 'TxtTagName_PID_1.Caption = stored MODULNAME TxtTagName53.Description = ReadValue("Fix32." + ps_datasource59.CurrentValue + "/DESC.A_CV") Exit SubErrorHandler: frsHandleError
End Sub
After using of "DeltaV Upgrade picture expert" that highlighted item do not change to DVYSY.
So when we point the curser on any datalink on the graphic pages , we see this error :
"Data source is unintended: Fix32.DVSYS.10PI-101/DESC.A_CV"
and when I do manually change from "Fix32." to "DVSYS." on the data link related expression , this error appeared:
"Data source is unintended: DVSYS.THISNODE.-025/DESC.A_CV"
Please guide me what is the best solution's for this Issue?
Tank you in-advanced.
