Does anybody have a good suggestion for alarming on an AO block? As you know, an AO block can be configured to have a READBACK signal. In this case, I would like to set it up to alarm on deviation (difference between SP and PV) and absolute values. I tried connecting an AO block to an ALM block (AO1/OUT to ALM1/SP, AO1/PV to ALM1/IN), however, there is an issue with the ALM block, where a changing SP will cause the deviation alarm not to work. You will get it to work once, following a download, but will not work again after that when it goes in and out of deviation range.
