While trying to load a phase manually from BOI phase control (for only specific unit instance) , load failure occurs. It shows fail message as " the provided parameter binding is invalid, parameter not found ". Whereas if we try to load same phase through unit faceplate it starts well ; also it runs on another unit instances on BOI. Can anybody suggest a cause & solution for this.
Harshad
In reply to Matt Stoner:
In reply to dharshad30:
