We have a Version 12 DeltaV system and we are trying to establish communication with an Atlas compressor. The communications coming off the compressor are CAN and going through and MK5 gateway to convert to Modbus RS485 communications (half duplex). We can use a ModScan program at the gateway and right before the DeltaV card and see the register values coming in and changing. However on the DeltaV Serial Card (S Series) and port, we are showing an intermittent "device failure" error show up in diagnostics. Everything seems to be mapped correctly, and we are asking for the right dataset types and registers. I have also tried to scale down the number of registers I am asking for (even down to one register) to see if I can clear the errors but I am having no luck. Has anyone else seen this type of issue on a Serial card talking Modbus through a gateway?
In reply to fairchdm:
In reply to DBacker:
