I have one query on Modbus connectivity on MOVs.
We are doing commissioning of SWRO Plant where all the MOVs are Modbus RS485 operated. In one loop there are 12-14 nos. of MOVs connected in series. Each MOV was tested individually from the PLC by forcing through soft an it was working fine. However when this was tested in logic, it gave problem when the third Step was to be operated.
For e.g there are 11 MOV in one skid. and the valve are operated in some sequence.
Step1: MOV-1, MOV-4 :ON. Step-1 will be for 10 min
Step2: MOV-1 remain ON, MOV-4: OFF, MOV-3 ON. Step-2 will be for 15 min
Step3: MOV-1 remain ON, MOV-2:ON, MOV-3:ON. Step-3 will be for 5 min.
Until step-2 the logic will work fine but when it comes to step-3, MOV-2 will not come to ON.
What might be the problem and what is the solution for it.
