hi all, i'm using the DeltaV scheduler for the first time in 11.3.1
I'm trying to create an on-change event so when a new user logs into the workstation, the event is triggered and writes to a deltav module with a string parameter. i have 2 questions:
1) the vb code to use?
2) using a simple vb script like 'msgbox"1" to test the event trigger, the event doesn't seem to trigger in the foreground with deltav operate running but does function if run in the background. Any ideas what may be preventing it running in the foreground or any diagnostics that i can do.
Thanks.
