DeltaV switch
Please,
We have one station on site that has not been integrated during the project phase. We should interface SM optical to cooper using a switch. Is it necessary to use Emerson switch or we can use any other switch?
  • Hi,
    is it a controller or OPS your missing?
    If it´s only to convert the signal e.g in the cabinet you could use the VE6019 Fiber-optic converter.
    These are unmannaged switches so it´s just Plug and Play, if you want produt support in possible problems you will by our product, if that isn´t important you by what you wan´t .
    (http://www2.emersonprocess.com/siteadmincenter/PM%20DeltaV%20Documents/ProductDataSheets/PDS_CtrlNetworkHardware.pdf)
    If you want to have the integration and security and then you should go with the smart switches.
    http://www2.emersonprocess.com/siteadmincenter/PM%20DeltaV%20Documents/ProductDataSheets/PDS_DeltaV_Smart_Switches.pdf
    Niklas Flykt
    Klinkmann Oy
    nikfly@gmail.com
  • In reply to Niklas Flykt:
    It is OWS station.
    Thank you!
