Dear All
i have 2 Engineering work stations in my project. i have assigned the Professional Station license to these stations and also the communication is
ok and i can download these stations from P+. but when i want to open Deltav Explore the message " Access in Denied" is appeared. i have assigned the P license but i dont know what is the problem !!!
it will be highly appreciated to solve my problem with your kind advises.
Best Regards
  • Please attach a screenshot of error message.
  • Dear Friends
    Also please consider attached file.
    Regards
  • In reply to Pouya:
    Hi Pouya,
    Do you have a workgroup or Domain enviroment?
    Check that you have the user rights to connect as admin/xx to  the PRO+ station...
    check that you have the DV users also  windows..
    run workstation configuration and try again..?
    edit: check that you have the same password for the DB at all stations
    Niklas Flykt
    Klinkmann Oy
    nikfly@gmail.com
  • Is this workgroup or Domain network?
    What user are you logging into Windows/DeltaV as, the same user as on the P+?
    Try connecting to P+ using UNC path \\P+NAME\DVDATA (substitute the P+NAME for your P+ workstation name).  Does it connect?
    From: Pouya [mailto:bounce-Pouya@community.emerson.com]
    Sent: Friday, August 15, 2014 5:22 AM
    Subject: RE: [EE365 DeltaV Track] Engineering Station (P station)
    Dear Friends
    Regards
