PHV command line argument for starttime earliest
Does anybody know the command line argument for setting the start time of Process History View to "Earliest"?
I have a button on a motor detail display that opens a history of trip events using a script like this:
sTripList = "CHS My_Trip_List.phvv /starttime (1/1/2014) /endtime * /module (" & Me.ModuleName.Caption & ")"
RetVal = Shell(sTripList, 1)
I would like to replace the specific date in the command with earliest, just as if I'd checked that box in the time filter dialog. I am sure that "/starttime earliest" worked in the past but my v12 system doesn't like it.
Thanks.
  • Hi Rob
    You can use the "DateTime.Date" to get the actual date.
    Example :
    sTripList = "CHS My_Trip_List.phvv /starttime (" & DateTime.Date & _
                ") /endtime * /module (" & Me.ModuleName.Caption & ")"
  • In reply to Jack_France:
    PS : If you plan to add time to the date, you must quote the whole data :
    sTripList = "CHS My_Trip_List.phvv /starttime """ & Now & _
                """ /endtime * /module (" & Me.ModuleName.Caption & ")"
    Note the replacement of the ( and ) by a double " inside the string., before AND after the date & time format.
    Jack,
    Thanks for the reply but setting starttime to a specific date or time is not the problem.
    How can I set it to "earliest" the same way that entering "/endtime *" sets the end time to "Latest"? I know I can set the start time to a date like 1/1/1900 as a workaround.
    Rob
  • In reply to RobPerry:
    So sorry Rob.
    I was mistaken about your question because I have confused the earlier data and "laster" one.
    So, excuse me but I don't know how to ask to the server what is the oldest date and time for a data.
