Dear Expert,
I have plan to have additional temperature controller, that are input from our analyzer whereas existing temp controller input base on temp transmitter. Existing temp controller will regulate re-boiler control valve.
Command button already created, with writevalue either "0" and "1" whereas when user select existing so the controller active should be existing controller (TIC-A) and when user select additional then should be additional controller (TIC-B) will be active.
Please need your advice regarding how to parsing value from commandbutton to controller and also how to control the temperature so that not exceed from certain value because if more than 155F will damage our seal pumps.
Thank you very much for your kind support
Peki
