I have face a problem regarding the Engineering Workstation. I have done some modification on Deltav Explorer recently and did not save a backup of that. Unfortunately the hard of EWS was broken. Now we need to restore an old image of EWS on the new hard but it dose not have the recent modification and database in the controller is not matched with the database in the DeltaV explorer. Could you please advice me how can I solve this problem? Will be upload from controller a solution? can that make distribution on the process? How can I do that?
- I have added two new transmitter on the explorer.
Thanks in advance.
As an option you may connect the broken HD as slave then disconnect the existing database from explorer and then again use the path from slave HD to connect the old database (including the new transmitter) and copy it.
