That's the second times that happend on different Simulate machine and don't know how to solve it :- The Simulate machine works fine- Creating a new Database- Set active this new database- ShutDown the DB server- Start the ReRun utility + type the correct password at the end of procedure + restart the machine- logging the machine- Flexlock "DeltaV loggon"... but the current (windows logging) user (that is the same as before) does'nt appears in the list; only got "Administrator, Configure and Maintainer"
The only user that accept loggin is Administrator.When I start DV Explorer and try to load the license file, the item menus "File + Licensing" are greyed : "Load License File" and "Create License File".If I select back to the previous Database, the problem is the same : License assignment disappears and the menu to load the license file is greyed.
The user exists in "user managment" account list.If I rename the user in the "user management" + recreate a new one with the same name (as the window user) + reboot, then the windows desktop is reinitialized and I definitively lost access to anything.The "WatchIt DongleDriver" says "RT_FAILURE" (error 7) - but works fine previously.
Questions :- Is there another way to load license file than from the explorer menu ?- Is there a reason why the user rights disappear after a ReRun ?By the way, I only have the solution to reinstall completly Windows and DV to be able to build a new databaseIf someone have an idea ...Some more details that could be important :- This simulate machine runs under VMWare Player 5.0.2- my dongle is supported on a parallel port LPT1 (and usualy works fine)
In reply to Maarten van der Waal:
Hi Maarten
You'r right !
I have never been surprised by the dongle deconnection during loggon/off and you are right : After logoff, the parallel port status is not connected.
I've connected it before re-loggin, Flexlock only provides "adminstrator" loggon, but I was able to load the license, attribute it to the PP node and then, after the download, the default user reappears in the available users list in the FlexLock.
Many, many thanx, Maarten.
The first time i've encountered this problem I was forced to create a new Simulate machine.
Ouf. Merci
Karma doesn't have any menu, you get serve what you deserve.
In reply to Kartik29:
In reply to Andre Dicaire:
Automation IT MES Engineer.
In reply to ctgarvey:
