Largest 5 values from set of Values
Currently i am working on college project, where i am getting 30  field values as input signals for DeltaV.
I want to compare those 30 values and get 5 largest values from those 30 values.
Is there any standard block which can help me to get the above mentioned results.
I know Calc block can help but i am not good with the coding.
Please kindly let me know in case if someone can help.
Thank you for your help and time.
  • In reply to Ashish P:
    Very Close... Here is my suggestion:
    IF IN1 = 1 THEN
    I:= 1 (* Initialize I *)
       I := '^/I.CV' + 1 ;
       J := '^/J.CV' + 1 ; (* Not Yet *)
       RANK := 16; (*Not Yet *)
    WHILE I <= 16 DO
             RANK := 16
             J := 1 (* Initialize J *)
      WHILE J <= 16 DO
    IF I <> J  (* Don't compare value against itself *)
      IF '^/FEILD_VALUE'Idea[1] >= '^/FEILD_VALUE'[J][1] THEN (* or equal to *)
    RANK := RANK-1
            END_IF;
    END_IF (*close the IF I added *)
                      J := J+1;
      END_WHILE;
            '^/FEILD_VALUE'Idea[2] := RANK;
                      I := I+1;
    END_WHILE ;
    ENDIF;
    The only problem so far is that if 2 numbers are identical, then the following rank will not exist, i.e. if 2 numbers are ranked 3rd because they are identical, then there will be no 4th ranked number...there will be a fifth ranked number.
    You can probably handle that in the presentation logic through looping as well.
    Many Thanks  Youssef.El-Bahtimy for your modifications. The above code worked.
    Just a slight modification at :
    IF I <> J THEN
    Otherwise code works perfect for all unequal values.
    I am working on that part now.
    Really appreciate a lot for all your help. Smile
    Thank you very much.
