Currently i am working on college project, where i am getting 30 field values as input signals for DeltaV.
I want to compare those 30 values and get 5 largest values from those 30 values.
Is there any standard block which can help me to get the above mentioned results.
I know Calc block can help but i am not good with the coding.
Please kindly let me know in case if someone can help.
Thank you for your help and time.
In reply to Ashish P:
Very Close... Here is my suggestion:
IF IN1 = 1 THEN
I:= 1 (* Initialize I *)
I := '^/I.CV' + 1 ;
J := '^/J.CV' + 1 ; (* Not Yet *)
RANK := 16; (*Not Yet *)
WHILE I <= 16 DO
RANK := 16
J := 1 (* Initialize J *)
WHILE J <= 16 DO
IF I <> J (* Don't compare value against itself *)
IF '^/FEILD_VALUE'[1] >= '^/FEILD_VALUE'[J][1] THEN (* or equal to *)
RANK := RANK-1
END_IF;
END_IF (*close the IF I added *)
J := J+1;
END_WHILE;
'^/FEILD_VALUE'[2] := RANK;
I := I+1;
END_WHILE ;
ENDIF;
The only problem so far is that if 2 numbers are identical, then the following rank will not exist, i.e. if 2 numbers are ranked 3rd because they are identical, then there will be no 4th ranked number...there will be a fifth ranked number.
You can probably handle that in the presentation logic through looping as well.
Many Thanks Youssef.El-Bahtimy for your modifications. The above code worked.
Just a slight modification at :
IF I <> J THEN
Otherwise code works perfect for all unequal values.
I am working on that part now.
Really appreciate a lot for all your help.
Thank you very much.
