Strange problem with a single OP station (3 stations on one console with identical config and area assignments, and same user) yet only two stations receive alarms from certain modules.
I've traced it to modules residing in an APP station (which has approx 3000 modules), setup data downloaded, modules downloaded, but still I can't get the alarms to appear on the OP station in question?!?!
What can I be missing?
Did you log all the way out of the Op station? I usually have to log all the way out (DeltaV and windows login) before recently assigned alarms/areas will show up on a particular Operate station.
When you call up a module faceplate, does the alarm show there?
