Refresh my memory!
I am running a Procedure. Simultaneously, we need to update formula values for the Procedure in the database so that next time we run it we will use the new formula values.
Can I download the Procedure in the Batch Executive while it is running without affecting the Procedure?
Version 11.3.1. I'm pretty sure you can in this version, but I wanted a double check assurance. Thanks.
In reply to MauryBayer:
Thanks Maury. I was also thinking about the 'Recipe Resynchronization' option for the Batch Rexecutive which would apply my new downloaded changes in-process, but only if I have that enabled, and with many conditions.
I looked this up in BOL under 'Recipe Resynchronization' to learn all about it.
