Unfortunatly a very simple task led to a few times of tries and errors.
After 13 month of use of DeltaV Live we now want to print (pdf-printer) something for the first time.
A digital checkliste shall be printed which is configurated as a contextual display. The code behind a BUTTON using the CLICK-action in the INTERACTION tab was finshed quite fast, but independent of the printing properties SCOPE, etc. only a blank page is the result of each print job (please find attached).
alldisplays.pdf
allscreens.pdf
Therfore I tried to use the print menu from the standard menu bar manualy. But it also results olny in some kind of frame-boarder.
Any advice?
brg Stefan
Stefan Müllner Senior Plant Engineer - Automation & Systems
METADYNEA AUSTRIA GmbH
In reply to Felix:
