I use Excel add -in and create report file but I need to print the report automaticly in special time , How can I do It?
Thanks & regards
It is possible with Microsoft Task Scheduler and an Excel Macro.
In reply to Alfred Pol:
do you excel macro template?
Another possible solution I have used before (with DeltaV Reporter) is to use a Visual Basic Script and run it using Windows task scheduler. The VBS can open an instance of Excel and print it out. Example below:
filename='Report.xls"
set oExcel = CREATEOBJECT("Excel.Application") 'open an instance of Excel
oExcel.visible = true 'show the instance, so we know what is going on
oExcel.Workbooks.Open(filename) ' Opens the Excel Workbook
oExcel.ActiveWorkbook.Worksheets.PrintOut 'Print current Workbook to default printer
oExcel.Quit ' Exit Excel Workbook
set oExcel = Nothing
In reply to Chris:
thanks
