Auto printing Daily report
I use Excel add -in and create report file but I need to print the report automaticly in special time , How can I do It?
Thanks & regards
  • It is possible with Microsoft Task Scheduler and an Excel Macro.
  • In reply to Alfred Pol:
    do you excel macro template?
  • Another possible solution I have used before (with DeltaV Reporter) is to use a Visual Basic Script and run it using Windows task scheduler.  The VBS can open an instance of Excel and print it out.  Example below:
    filename='Report.xls"
    set oExcel = CREATEOBJECT("Excel.Application") 'open an instance of Excel
    oExcel.visible = true 'show the instance, so we know what is going on
    oExcel.Workbooks.Open(filename) ' Opens the Excel Workbook
    oExcel.ActiveWorkbook.Worksheets.PrintOut 'Print current Workbook to default printer
    oExcel.Quit ' Exit Excel Workbook
    set oExcel = Nothing
