Anyone know if the ability to have a Gateway address to a PK controller 3rd party NIC has been added for V15, or if this is even in the works?
Curious as to the thought process of not having the ability to add a gateway, it is rare for us anyway to have a single LAN segment with switching in the same building, to limit physical switches, we utilize VLAN's, and use firewalls to route all traffic. Having a PK in one area of the plant to utilize the 3rd party communications to a node located in a completely different area, we create a VLAN with a /29 subnet but since all the traffic is routed using Dot1Q just putting the PK on the network does not work without having to add a bunch of static routes and creating a VPLS tunnel to get there.
At least that is all I have been able to come up with. Anyone else have any ideas??
Emerson, was the scenario of a customer using routing and VLANs for all layer 2.5/3 networks not considered, or is there a solution I am missing?
