Can someone explain how can we access the HART devices from a 3rd party systems thru Modbus TCP on PK Controllers in AMS? The DeltaV version is v14.3.
Which interface are we going to select in AMS? Is it the DeltaV Network?
Thanks for your replies.
In reply to Andre Dicaire:
That means, it's either the conventional or the HART-IP interface.
For conventional, the HART devices from 3rd party will be connected to HART-Mux then to Converter via RS485, then to AMS Server via RJ45. The RJ45 port of the PK controller is not meant for this purpose.
For HART-IP interface, we just need the license. The HART-IP Interface is available with AMS Device Manager version 14.0 and higher.
Below are the supported HART-IP Host Systems:
-Tricon CX v11.5
-HIMax Major Version 5
-Phoenix Contact Ethernet HART® Multiplexer
